rayterry
Aug 10, 2021Apprentice
Can't connect to internet perhaps because 0.0.0.0 doesn't seem like the right IP Addr
I'm stuck. Config on the Orbi got blown away so I reset back to factory settings, but I cannot connect to the internet. As seen in the attached pic the INTERNET PORT IP Address shows as 0.0.0.0. T...
- Aug 10, 2021
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQIf you can find the model # of the ISP modem, would be helpful.
rayterry wrote:
Thanks to all for reading. Powering off the cable modem and Obri router for 1 min got things quite a bit further. Thanks! At least Orbi thinks I'm connected to the internet and I was able to connect and use things as usual... for about 5 or 7 mins. Then things slowed down and stopped. Orbilogin still shows Internet Status "GOOD", but trying to bring up a webpage stalls with cannot connect to internet. ??? Strange that things worked for a bit and then stopped.
I'm using an Orbi RBR40, on v2.7.3.22, 2 satellites attached, 27 devices
The Xfinity cable modem is in bridge mode. Not sure of the model, etc as I'm not finding any such info on the modem. It is only a couple months new from Xfinity/Comcast. I've rebooted the Orbi many times and same with the cable modem and the iMac I'm typing on now.
Any ideas what to try now to finish this off?
Thx!!!!!!
CrimpOn
Aug 10, 2021Guru - Experienced User
rayterry wrote:
I'm stuck. Config on the Orbi got blown away so I reset back to factory settings, but I cannot connect to the internet. As seen in the attached pic the INTERNET PORT IP Address shows as 0.0.0.0. That doesn't seem right, but I'm not finding where in the gui to change that to (I assume???) the ip of the router. Help...
Correct. This is not right. This Orbi is set to ask the ISP for an IP address using the DHCP protocol and has not received one. This is not something the user keys in unless he has paid for a static IP.
Need to check the status of the ISP modem.
Can you connect a computer (PC, Mac, laptop) directly to the modem and verify that it is working correctly?
(We are assuming that this ISP does not require you to enter a user name and password to get connected, which would be a PPPoE setup rather than DHCP.)
