ztekdesign
May 08, 2019Aspirant
Can't connect to my work VPN
Since installing the Orbi sytem I can no longer connect to my works VPN using Remote Destop. Is there something needs to be setup in Orbi for this? It works just fine using my old router or using my ...
ztekdesign
Orbi is operating in Router Mode and its running the latest version of firmware. The ISP is a wireless comany and they simply have a radio on the roof of my home that connects to their tower. Not sure of the hardware make or model. It works fine if I plug one of my old routers in place of the Orbi. I doubt it's my ISP or their hardware.
I contacted Netgear support and they told me I need to add a VPN service to Orbi. Isn't that only so I can connect to my home network when I am outside my home? I want to be at hom and connect to my work computer using remote desktop. Something that is very common these days. Not sure why they would tell me that.
May 08, 2019Guru - Experienced User
You might try this, reconnect you old router back online. Reconfigure the Orbi for AP mode and connect it to the old router. Be sure to disable ALL wireless radios on the old router.
Does your VPN work in this configuration?
Do you have any parental controls or any security apps enabled on the Orbi currently?
- ztekdesignMay 08, 2019Aspirant
I will give it a try tonight. To be honest if I have to use my old router then the Orbi system is going back. I love the sytem so far other than this issue and to be honest this is a big issue if I can't work from home.
I do not have any parental controls setup.
- FURRYe38May 08, 2019Guru - Experienced User
Do you know if the ISP and there modem use any kind of static IP or PPPoE configurations? or just Dymamic DHCP IP addressing thats just connect any router and get an IP address?
They just use Dymamic DHCP
