ztekdesign
May 08, 2019Aspirant
Can't connect to my work VPN
Since installing the Orbi sytem I can no longer connect to my works VPN using Remote Destop. Is there something needs to be setup in Orbi for this? It works just fine using my old router or using my ...
gr8sho
May 08, 2019Virtuoso
ztekdesign wrote:
Since installing the Orbi sytem I can no longer connect to my works VPN using Remote Destop. Is there something needs to be setup in Orbi for this? It works just fine using my old router or using my phone as a hot spot. Something in Orbi is blocking the connection.
Client side VPN should work fine without any intervention on the Orbi. I have one client here using NORDVPN without any issues, and over time I expect more of the clients to be using VPN connections.
- ztekdesignMay 08, 2019Aspirant
I agree it should work. I just got done speaking with Netgear support and they are now telling me that I need to engable and install OpenVPN in order to get the Remote Desktop to work. I've owned and setup hundreds of routers over the years and have never had to do this just to use Remote Desktop. Either they are telling me wrong or this device is going to be a huge problem for the average user. Something doesn't add up.
- gr8shoMay 08, 2019VirtuosoThey must be misunderstanding you. If it’s a foreign call center, they might just be reading off a flowchart.
- ztekdesignMay 13, 2019Aspirant
After many calls to Netgear support and many hours of trying differtly things I never could get Remote Desktop to work so I boxed it up and sent it back. Just purchased a Ubiquiti AmpliFi HD unit and it works great. Signial is strong throught the house and my Remote Desktop works like it should without any issues or extra setup.
