Mac1303
Aug 28, 2019Follower
Cant connect to orbi rbk50. It says password not correct. How do yu reset a network password ?
Orbi rbk50 router. I changed the network name and password. Now i try to connect to the network and it says password is incorrect? How the heck do you reset a network password?
michaelkenward
Aug 29, 2019Guru - Experienced User
I assume, like CrimpOn , that you are talking about the wifi password rather than the browser graphical user interface.
If not, a factory reset is the only way to get back in when the password really is forgotten.
