kaboomsmom's avatar
kaboomsmom
Unable to get updated firmware ver 1.0.0.42 into the WNR2000v5 router, N300 WiFi router
I've done the following, after extracting the file, which is: WNR2000v5-V1.0.0.42.img and was extracted to my hard drive PC running Windows 7) as well I placed it onto my desktop so it's easy to get ...
  • kaboomsmom's avatar
    kaboomsmom
    Jul 11, 2017
    I finally got the download done. It was the adaware program interfering with the download. Thank you for your response...
    Cindy
