alphabeta77
Jul 31, 2021Tutor
Can't connect to RBK50 admin after power cut
Hi all, Had a brief power cut this morning for a few seconds and haven't been able to connect to my Orbi since. Tried rebooting and same occurs. On WiFi it gives IP configuration failure as an err...
alphabeta77
Jul 31, 2021Tutor
Ok, the plot thickens... Finally got in, but I don't recall having 200+ satellites, should I sell 195 of them on eBay?
I can't imagine what the admin app is doing, but clearly it's not right in the head???
- plemansJul 31, 2021Guru - Experienced User
Storms are great at wrecking things.
I'd recommend manually installing the firmware to it, then doing a factory reset, and a reinstall.
If the storm corrupted something in the firmware or settings, this would correct either of those.
