pmauro's avatar
pmauro
Can't connect to router settings from Satellite
If I try to access the router settings, it doesn't work unless I am next to the router. If I move from a satellite to a location next to my router, I have to turn off the wifi on my mac for a couple of minutes and turn it back on before it will work.
Any ideas?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to access the settings using the IP address of 192.168.1.1 instead of orbilogin.net?
    DarrenM
