IainJ's avatar
IainJ
Follower
Jan 19, 2020
Cant Connect to Router
I have just purchased the ORBI RK23 and trying to set-up an connect.  However when using the ORBI Ap it keeps having an issue at the last stage and wont connect to the router.  It then suggests going...
  • CrimpOn's avatar
    Jan 19, 2020
    A brand new Orbi should come up with the WiFi name (SSID) and password printed on the label.
    However, if this Orbi was previously purchased, set up, and then returned (for example, to Costco, Amazon, Best Buy), then it may no longer be in "factory condition."
    An easy test is to get out a paperclip, unbend part of it, and stick the end into the tiny "Reset" hole next to the power LED on the back.
    Hold the paperclip in the hole until the power LED turns amber, and then begins to flash.  (This can take 15-20 seconds. Be patient.)
    At that point, the Orbi should have been "reset to factory", and should broadcast the SSID/password on the label.
