BRorbi
Mar 20, 2022Guide
Can't connect to routerlogin.net or .com anymore
Almost 2 weeks ago, I changed my ISP from Spectrum Cable to AT&T fiber with a gigabit service. Behind the required AT&T gateway I wired my orbi mesh system and the wireless function on the gateway we...
Mar 20, 2022Guru - Experienced User
Do you have the CBR40 or the RBR40 for the router?
Att's devices are sketchy on their passthrough mode. And having their gateway causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions. Again, att's devices seem to work poorly in passthrough mode in my experience
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- BRorbiMar 20, 2022Guide
It is an RBR40, even though I don't know what CBR40 is.
I need to leave the RBR in router mode, not access mode. With the satellites, I can reach the whole house. With the gateway acting as a router, I would need to buy wifi extenders to reach the house.
I am heading out of town, so I will be back tomorrow to study your reply further. I will start by following the link for a Double-NAT. The darn printer I use is out of sync again with my desktop and that alone is a nuisance. I have no idea why the IP addresses keep changing between 10s and 192s.
I will post back here once I have some intelligent followup questions to ask.
Thank you for helping.
Bruce
- plemansMar 20, 2022Guru - Experienced User
your ip address is changing because you have 2 devices in router mode on your network assigning ip addresses.
Thats the double nat.
- BRorbiMar 20, 2022GuideYes I figured that out about the double NAT part. One question before I go on the road. By disabling the wifi of the gateway, is that different from creating a bridge mode of the gateway? The wifi of the gateway was already disabled, and it appears to ALSO be in n bridge mode on the home network tab. I will be back tomorrow to study this further, but I wanted to make sure I know the answer to my question above. Thanks again.
- ale1976Mar 20, 2022Aspirant
