BRorbi
Mar 20, 2022Guide
Can't connect to routerlogin.net or .com anymore
Almost 2 weeks ago, I changed my ISP from Spectrum Cable to AT&T fiber with a gigabit service. Behind the required AT&T gateway I wired my orbi mesh system and the wireless function on the gateway we...
Mar 20, 2022Guru - Experienced User
Do you have the CBR40 or the RBR40 for the router?
Att's devices are sketchy on their passthrough mode. And having their gateway causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions. Again, att's devices seem to work poorly in passthrough mode in my experience
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
ale1976
Mar 20, 2022Aspirant
