RobLaRu
Sep 13, 2019Aspirant
Can't Connect to SAP on Company VPN since installing ORBI
I work from home. Prior to installing this Orbi router, I would connect to my company VPN, then connect to SAP. Since installing this router. I can still connect to the VPN and all other services wor...
- Sep 14, 2019
Put computer in DMZ, still no joy. Uninstalled Orbi, installed new Eero wifi router, Now I can get on SAP. So goodbye Orbi, hello Eero!
CrimpOn
Sep 13, 2019Guru - Experienced User
If you are not the only person connecting from home, maybe the company IT people have "seen this before"?
Could you please describe what the Orbi is connected to? (brand and model number).
RobLaRu
IT is involved, they have re-imaged my laptop and upgraded the client. They have not seen this before. The Orbi is connected to a Netgear CM700 modem.
- FURRYe38Sep 13, 2019Guru - Experienced User
Not a long term solution, however what happens if you put your VPN PC into the Orbi's DMZ then try to connect to the remote VPN?
Is the PC wired or wireless connected to the Orbi?
