RobLaRu
Sep 13, 2019Aspirant
Can't Connect to SAP on Company VPN since installing ORBI
I work from home. Prior to installing this Orbi router, I would connect to my company VPN, then connect to SAP. Since installing this router. I can still connect to the VPN and all other services wor...
- Sep 14, 2019
Put computer in DMZ, still no joy. Uninstalled Orbi, installed new Eero wifi router, Now I can get on SAP. So goodbye Orbi, hello Eero!
CrimpOn
Sep 13, 2019Guru - Experienced User
On the Orbi web interface, select the Advanced Tab->Setup->WAN Setup
At the top of the page is a box to enter the IP address of one device. The Orbi will forward every packet that comes in to this device. The typical use of DMZ is for things like web servers. With a strong Windows firewall, most of the junk should bounce off.
