aalvarad
Sep 29, 2020Aspirant
Cant connect using my company VPN
All works well, but when I try to establish a VPN with my company then it doesnt work. I am simply not able to connect to my company via VPN. That is deal breaker. Help
CrimpOn
Sep 29, 2020Guru - Experienced User
aalvarad wrote:All works well, but when I try to establish a VPN with my company then it doesnt work. I am simply not able to connect to my company via VPN.
Many users report using VPN with the Orbi system. Perhaps if you identify the specific VPN others can comment on how they got connected. Ordinarily the brand of ISP modem is something to ask about, but the CBR40 includes a cable modem in the router, so you (literally) have no ISP device, correct?
