melannie_mark
Mar 24, 2020Tutor
Cant connect
Just got the RBR40 Router with 2 satalites. I went throught the process of setting it up. Got both satalites to glow blue and I can see the router name on my wifi list of networks but when i click on...
- Mar 24, 2020
Poor cat!! it is working!! that was it... needed to go back to factory settings.
thanks
CrimpOn
Mar 24, 2020Guru - Experienced User
Satellites glowing blue means that they successfully connected to the Orbi. How did the Orbi router "glow"?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
How are you managing the Orbi system? (Orbi web interface from the laptop or Orbi "app" usiing a smartphone or tablet)?
melannie_mark
Mar 24, 2020Tutor
router is white and i have connected with the app on my iphone. Should i try to do it throught the website?
- melannie_markMar 24, 2020Tutor
I think i just got it to work. i read one of your other posts about reseting it to factory settings and i think that worked... hang tight...
- CrimpOnMar 24, 2020Guru - Experienced User
Holding my breath. Cat looking at me strangely......
thanks
