capacytron
Feb 28, 2024Aspirant
Can't coonect Orbi RBR50 satellite after moving to new appartment
I have Orbi RBR50 + 1 satellite, firmware version 2.7.4.24 There were no issues with it in old apartment. I moved, head device works well, connected to internet and does the thing. For some reaso...
- Mar 01, 2024
Schema needs to look this way
INTERNET
telia_router
lan_port_0 lan_port_1
RBR
RBS
CrimpOn
Feb 29, 2024Guru - Experienced User
capacytron wrote:
i even plugged satellite directly into router (provider device) to exclude any broken wire / plug issue, no luck.
The satellite cannot be connected directly to an ISP device. It must be connected to the Orbi router (RBR50).
Does the satellite connect correctly over WiFi?
capacytron
Feb 29, 2024Aspirant
Why it can't be connected via ISP service?
I guess I try to build this schema. Same worked for previous appartment
> The following image shows how to connect your Orbi satellites and your Orbi router to an Ethernet switch
My ISP router has WAN and LAN ports. I both Orbi head and satellite are connected to lan.
Anyway, satellite and head Orbi are just 5 meters away. I even tried to place them in 10 centimiter distance, no luck. Satellite doesn't work
- CrimpOnFeb 29, 2024Guru - Experienced User
That article clearly shows satellites connected to the Orbi router, not to the ISP device.
An Orbi satellite will connect to the Orbi router in only two ways:
- Using a 5G WiFi connection (the default)
- When connected to one of the Orbi router LAN ports.
- capacytronFeb 29, 2024Aspirant
hi, this I don't fully follow...
Please have a look at the third configuration, RBR and RBS connected via switch.
My config looks this way:
INTERNET
telia_router
RBR RBS
why it wouldn't work?
