capacytron
Feb 28, 2024Aspirant
Can't coonect Orbi RBR50 satellite after moving to new appartment
I have Orbi RBR50 + 1 satellite, firmware version 2.7.4.24 There were no issues with it in old apartment. I moved, head device works well, connected to internet and does the thing. For some reaso...
- Mar 01, 2024
Schema needs to look this way
INTERNET
telia_router
lan_port_0 lan_port_1
RBR
RBS
capacytron
Feb 29, 2024Aspirant
Why is it a problem... ? I just moved devices from one apartment to another... Why would FW affect it? they were just few hours offline.
Feb 29, 2024Guru - Experienced User
Check LAN cabling between the RBR and RBS. CAT6 UTP is recommended.
Any LAN switches in between them? If so, brand and model please.
- capacytronFeb 29, 2024Aspirant
My schema looks this way
INTERNET
telia_router
RBR RBS
telia_router is SAGEMCOM C5 50001
- FURRYe38Mar 01, 2024Guru - Experienced User
INTERNET
telia_router
RBR
RBS
- capacytronMar 01, 2024Aspirant
Okay, thanks for your time, my bad.
I completely forgot that RBS was not connected to wire in my old apartment. I've disconnected it and it was immediately discovered by RBR... So stupid, thanks!
