capacytron
Feb 28, 2024Aspirant
Can't coonect Orbi RBR50 satellite after moving to new appartment
I have Orbi RBR50 + 1 satellite, firmware version 2.7.4.24 There were no issues with it in old apartment. I moved, head device works well, connected to internet and does the thing. For some reaso...
- Mar 01, 2024
Schema needs to look this way
INTERNET
telia_router
lan_port_0 lan_port_1
RBR
RBS
capacytron
Feb 29, 2024Aspirant
Why it can't be connected via ISP service?
I guess I try to build this schema. Same worked for previous appartment
> The following image shows how to connect your Orbi satellites and your Orbi router to an Ethernet switch
My ISP router has WAN and LAN ports. I both Orbi head and satellite are connected to lan.
Anyway, satellite and head Orbi are just 5 meters away. I even tried to place them in 10 centimiter distance, no luck. Satellite doesn't work
CrimpOn
Feb 29, 2024Guru - Experienced User
That article clearly shows satellites connected to the Orbi router, not to the ISP device.
An Orbi satellite will connect to the Orbi router in only two ways:
- Using a 5G WiFi connection (the default)
- When connected to one of the Orbi router LAN ports.
- capacytronFeb 29, 2024Aspirant
hi, this I don't fully follow...
Please have a look at the third configuration, RBR and RBS connected via switch.
My config looks this way:
INTERNET
telia_router
RBR RBS
why it wouldn't work?
