capacytron
Feb 28, 2024Aspirant
Can't coonect Orbi RBR50 satellite after moving to new appartment
I have Orbi RBR50 + 1 satellite, firmware version 2.7.4.24 There were no issues with it in old apartment. I moved, head device works well, connected to internet and does the thing. For some reaso...
- Mar 01, 2024
Schema needs to look this way
INTERNET
telia_router
lan_port_0 lan_port_1
RBR
RBS
capacytron
Feb 29, 2024Aspirant
My schema looks this way
INTERNET
telia_router
RBR RBS
telia_router is SAGEMCOM C5 50001
Mar 01, 2024Guru - Experienced User
INTERNET
telia_router
RBR
RBS
- capacytronMar 01, 2024Aspirant
Okay, thanks for your time, my bad.
I completely forgot that RBS was not connected to wire in my old apartment. I've disconnected it and it was immediately discovered by RBR... So stupid, thanks!
- FURRYe38Mar 01, 2024Guru - Experienced User
đ
Ok, ya any RBS that's ethernet connected, needs to be connected serially behind the RBR, router or AP mode. And not in parallel to the RBR.
