Lanis
Apr 07, 2018Aspirant
Can't do firmware update
My Orbi is running firmware 2.0.1.4 (stable for 3 weeks) connected to an iMac, OS 10.13.4. I read about firmware 2.1.3.4, so downloaded it for manual update. I can log into my router, click on and ...
Apr 07, 2018Guru - Experienced User
What browser are you using? Try Safari or FF browsers. Clear browser caches before and after trying to load the FW. Do no navigate to any other pages. Disable any PC security software temporarily.
Be sure that your wire connected with the Mac to the router.
Factory reset the router and set up from scratch if and when you get it loaded.
If your not having any problems, you might keep whats already loaded. You don't have to update.
- LanisApr 07, 2018Aspirant
I normally use Firefox, so you convinced me to try Chrome. It let me in to the Firmware Update module without hesitation. Now I have a different issue.
I have a different Orbi system (RBR50 + 1 Satellite) in a different house. That system gave me a message to update my firmware to 2.1.3.4, which I did successfully. This system, now that I am in the Firmware Update module, does not show my the 2.1.3.4 update.
I wonder why one Orbi shows the update to me and the other system does not.
The next question would be: would I be in trouble if I do the manual update on this system, even though it is not giving me the recommendation to do this update?
- loomis1975Apr 07, 2018Luminary
Lanis wrote:I normally use Firefox, so you convinced me to try Chrome. It let me in to the Firmware Update module without hesitation. Now I have a different issue.
The 2.1.3.4 was only pushed to auto update (what you saw in the firmware update module) for just a handful of days before Netgear pulled it. Why they pulled it? Don't know why. It IS a beta, which in my mind shouldn't be sent out for auto updating in any case. So thats why you saw it on one system's firmware page and not the other. You wouldn't be in trouble if you did the manual update, the 2.1.3.4 beta firmware is just as valid on your one setup as the other.
- FURRYe38Apr 07, 2018Guru - Experienced User
You can do a manual update if you have the files already.
I recommend being wired with the router and satellite with a PC.
