JRestivo
Sep 28, 2020Aspirant
Can't Downgrade RBS50 Sattellite Firmware
I'm trying to dowgrade the RBS50 from 2.7.0.70 to 2.5.1.16 but get the following error when manually trying to install the firmware: This firmware file is incorrect! Please get the firmware file ...
Mstrbig
Sep 28, 2020Master
I would upgrade the router back to 2.7.0.70, set everything up and then check settings. When I updated my system, certain settings got set back to default. I can verify that the new firmware is stable and fast, as long as the settings are correct.
So check these settings:
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
JRestivo
Thank you. I'll give a try and post the outcome.
