jesusrop
Jun 23, 2019Aspirant
Can't enable Daisy-chain
Hi, after the update to las firmware version my ORBI's have been unstable. Today i tried to fix the whole thing and to my surpirse daisy-chain is disabled. In my current setup daisy-chain is a must ...
Jun 24, 2019Guru - Experienced User
"Satellite 1 is just above the router" What is the distance between the RBS and router?
Try a factory reset on the 2nd RBS as re-add it, if the suggestions from CrimpOn fail...
