jesusrop
Jun 23, 2019Aspirant
Can't enable Daisy-chain
Hi, after the update to las firmware version my ORBI's have been unstable. Today i tried to fix the whole thing and to my surpirse daisy-chain is disabled. In my current setup daisy-chain is a must ...
Jun 27, 2019Guru - Experienced User
Any progess on this?
jesusrop wrote:Hi,
after the update to las firmware version my ORBI's have been unstable. Today i tried to fix the whole thing and to my surpirse daisy-chain is disabled. In my current setup daisy-chain is a must as the router has to be in the basement.
In satellyteip/debug.htm i see a checkbox to disable daisy-chain which is ticked and disabled (i can't change the value). it does not change regardless of what I do in the router daisy-chain checkbox.
Is there a way to force daisy-chain to be enabled again? Maybe through telnet?
Thank you!
