jesusrop
Jun 23, 2019Aspirant
Can't enable Daisy-chain
Hi, after the update to las firmware version my ORBI's have been unstable. Today i tried to fix the whole thing and to my surpirse daisy-chain is disabled. In my current setup daisy-chain is a must ...
jesusrop
Jun 27, 2019Aspirant
Hi,
The distance from router to satellite-1 is 3 meters in vertical (it is one story above, in the same position).
2 days ago I factory reset all 3 devices and applied all the configuration manually from scrap (I did the same but restoring configuration from a Backup and didn't work). It has been working quite well since then, but I'm still wqtching it.
Thank you!
Thank you!
Jun 27, 2019Guru - Experienced User
3 meters to too close, try 10 meters.
