mnspink's avatar
mnspink
Can't Enable VPN after V1.12.0.18 Update
After updating the firmware, I cannot enable VPN (I previously had it enabled).
I re-enabled Dynamic DNS, and when I click the Show Status button, it returns "x.mynetgear.com updated successfully at TIME"
However, when I click on "Enable VPN Service" and then click "Apply", the screen just refreshes and the check-box goes back to unchecked.
Any ideas?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Did you try to use another web browser?
    DarrenM
      • DarrenM's avatar
        DarrenM
        Try Internet explore also make sure a pop up blocker or firewall is no causing a issue.
        DarrenM
