DasRedBeard
Feb 17, 2017Aspirant
Cant figure out port forwarding. Now having issues with Sat not connecting internet.
Heres the layout. One Comcast modem (TG1682G) that my parents computer is wired too on the first floow . I Have the router connected to the modem. The satellite is on the second floor in my room with...
st_shaw
Feb 17, 2017Master
If you reset the units, you will need to go through the setup process again. It's possible the login information revereted to the default also.
If your comcast modem is a router and your Orbi is in router mode--then you will need to forward ports on both. (You should instead use AP mode on the Orbi.)
If your comcast modem is a router and your Orbi is in AP mode--then you will need to forward ports on the Comcast.
If your comcast modem is not a router and your Orbis is in router mode, then you will need to forward ports on the Orbi.
