GWild
Feb 10, 2021Guide
Can't find latest CBR40 Firmware as Described in Security Bulletin
Security bullitens list this info:
NETGEAR has released fixes or hotfixes for an unauthenticated command injection security vulnerability on the following product models:
- CBR40, running firmware versions prior to 2.6.1.38
But on the download page only this is listed:
Firmware and Software Downloads
- Current Versions
- CBR40 Firmware Version 2.5.0.14
Where do I go to find the latest release?
Even weirder: the RBS20 firmware (2.6.2.104) they have that is supposed to fix this hole is not compatible with my RBS20. Too funny.
Top Support Articles
- EU Declarations of Conformity
- RBR20 / RBS20 Firmware Version 2.6.2.104
Where do you find this information?
Nothing posted yet on NG download site:
https://www.netgear.com/support/product/CBK40.aspx#download
Something to contact NG support about and see.
- GWildGuide
The RBS20 firmware link that my slave says is incompatible is at:
https://www.netgear.com/support/product/RBS20.aspx#download
Top Support Articles- EU Declarations of Conformity
- RBR20 / RBS20 Firmware Version 2.6.2.104 <=====
- Which security features does my Orbi WiFi System support?
- Security Advisory for Security Misconfiguration on Some Routers, Range Extenders, and Orbi WiFi Systems, PSV-2020-0112
- Security Advisory for Unauthenticated Command Injection Vulnerability on Some Extenders and Orbi WiFi Systems, PSV-2020-0301
- Security Advisory for Stored Cross Site Scripting on Some Routers and Orbi WiFi Systems, PSV-2018-0539
You need to use what is avialable from the CBK site:
Untill NG makes it compatible with the CBR40.
