Bujinkage
Jun 18, 2018Aspirant
Can't Find The Satellite
Hi guys,
I hope someone is going to be able to help me. So, I did an update of the firmware and since then my router doesn't seems to be able to find my satellite. I can get through the interne...
Jun 19, 2018Guru - Experienced User
What is the distance between the satellite and router?
As last resort, I would do a ERASE on both satellite and router, then set up from scratch. Besure the satellite is starting distanct of about 30 feet from the router. Depending on building materials.
If the satelite still fails, possible that the satellite unit is bad and needs to be replaced. Something to ask NG for an RMA about.
