d4dr0ck
Apr 08, 2019Tutor
Can't Get Close to Gigabit via WiFi
I recently, with great help from Chuck_M and others here, reset and rebuilt my Orbi network. Content that all was well again at home, I allowed myself to be talked into trying Xfinity's Gigabit serv...
Apr 08, 2019Guru - Experienced User
Some wifi devices will not get anywhere near 900Mb. Most average around 400-500Mb.
If you have devices that support 160Mhz then maybe. You'll have to talk with each device Mfr to see what bandwidth and speeds are really supported by them.
Ethernet should see on average 900Mb +-.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
d4dr0ck
Apr 08, 2019Tutor
FURRYe38 wrote:
What Firmware is currently loaded? 2.3.1.44
What is the Mfr and model# of the ISP modem the NG router is connected too? Xfinity calls it an XB6. I don't know who builds it for them or what it might really be called.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. No need to take you down this road. Bottom line is before swapping out the modems in support of the gigabit service, the network was solid and just about anywhere inside or out I could peg the needle at what I was paying for (150-170mbps). It's still solid, but just not delivering enough of what I'm paying for to justify the added cost.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. That stuff is all enabled.
Thanks for your thoughts and information. At this point, if I can't realize gigabit in real world uses, as a result of a limitation in the WiFi standards or whatever, I'll probably just tell Xfinity to cut me back down to where I was. No big deal. Thanks again.
- michaelkenwardApr 09, 2019Guru - Experienced User
As others have explained, Gigabit via WiFi is unrealistic. (I'm surprised that anyone expects to get those speeds.) However, if speed is important to you before you drop back to a slower Internet service, think about other options.
Wired devices are inherently faster than wireless. If you can wire some of your stuff, that will squeeze more speed out of the system.If it is a case of avoiding running wires all round the place, the Powerline Ethernet can be faster than wifi albeit not as fast as direct wired ethernet.
Then again, apart from speedtests I wouldn't expect to see much difference between 500 Mbps and 1 Gbps.
- d4dr0ckApr 09, 2019Tutor
As I said, I understand there's a dropoff between the speed a modem delivers and what you see via WiFi. My surprise is just that the dropoff is so pronounced, but now I know. The truth is I don't need gigabit, and on more examination, the real world gain I'm seeing with it is far from worth the additional cost.
Yep, I've got a switch next to the router that supplies the things that are either most dependent on max bandwidth or most susceptible to WiFi flakiness. I appreciate hearing that Powerline Ethernet is a good option.
Thanks for taking the time to weigh in.
