Jschnorr
May 22, 2019Aspirant
Can't get Epson DS-560 connect to Orbi RBK23
Hi,
I just switched to the Netgear Orbi RBR23 system. Works great. However I can get my Epson DS-560 scanner working. Neither using a Mac or Windows 10 PC.
I am using the Epson Netconfig Tool...
Jschnorr
Hi Plemany,
Thx for your quick reply. Correct I am living in Europe/Germany and the region of the Orbi is set to Europe.
If I do what you are suggesting and as soon as I have my scanner connected. Can or should I go then back to 2.4GHz Channel and select auto?
BR
Juergen
May 22, 2019Guru - Experienced User
I would do a wireless scan and see what channel is the best and just set it there. Try to use channels 1-6-11.
I figure the printer must be set on US settings and unable to use channels 12,13 so if you go back to auto and the orbi switches to those, the printer will drop off the network.
- plemansMay 22, 2019Guru - Experienced User
Only reason I mentioned the wifi printer reservation is that it keeps the printer from switching to a different IP address during random power outage, lease expirations, etc. That way once its installed to a computer, it usually just works. Otherwise you're having to reinstall it to your computer whenever it changes IP addresses.
- JschnorrMay 22, 2019Aspirant
Thx again. Final question. Hopefully. If I would go to the Advanced Wif settings on the Orbi setup page there is a under advanced settings (at the bottom) Wireless Configuration. There I can choose a region. Currently it is set to Europe. If I switch it there to US it should work as well? This way I would the access point choose the channel which would be best. Correct?
Scanner is from the US. Moved just back from NC to Germany. I already had to give up on my Google Wifi - they did not pair with the European version....
I would leave it set to europe like you have it. Setting your wifi channel instead of leaving it on auto isn't a big issue and keeps you from any regulatory problems. :)
