Jschnorr
May 22, 2019Aspirant
Can't get Epson DS-560 connect to Orbi RBK23
Hi,
I just switched to the Netgear Orbi RBR23 system. Works great. However I can get my Epson DS-560 scanner working. Neither using a Mac or Windows 10 PC.
I am using the Epson Netconfig Tool...
Jschnorr
Thx again. Final question. Hopefully. If I would go to the Advanced Wif settings on the Orbi setup page there is a under advanced settings (at the bottom) Wireless Configuration. There I can choose a region. Currently it is set to Europe. If I switch it there to US it should work as well? This way I would the access point choose the channel which would be best. Correct?
Scanner is from the US. Moved just back from NC to Germany. I already had to give up on my Google Wifi - they did not pair with the European version....
May 22, 2019Guru - Experienced User
I would leave it set to europe like you have it. Setting your wifi channel instead of leaving it on auto isn't a big issue and keeps you from any regulatory problems. :)
