opus123
Apr 29, 2021Star
Can't get full download speed from wired connection
I've been playing around with this for the last few days. My issue: I have the 1000 down plan from my cable co. I was renting their modem/router combo which I had the wireless turned off and had ...
- May 01, 2021
15 second press of the reset button and release is all thats needed. Walk thru the setup wizard with a wired PC and web browser. Be sure to not enable Access Controls, Armor, Circle or Traffic Meter. Try a speed test with Ooklas installable speed test app with the wired PC.
Apr 30, 2021Guru - Experienced User
Factory reset the orbi.
Then during the install make sure to leave qos, access control, parental controls, and access controls disabled.
After the initial setup, try testing the speeds.
don't use the built in nighthhawk test app but use speedtest over a wired connection.
What firmware version are you on?
opus123
Apr 30, 2021Star
plemans wrote:Factory reset the orbi.
Does a factory reset get rid of the prior speedtest numbers? I've done one reset of the Orbi yesterday and everything seemed reset but on the qos screen it still showed the numbers from the last speedtest.
