opus123's avatar
Apr 29, 2021
Can't get full download speed from wired connection
I've been playing around with this for the last few days.   My issue: I have the 1000 down plan from my cable co. I was renting their modem/router combo which I had the wireless turned off and had ...
  • FURRYe38's avatar
    15 second press of the reset button and release is all thats needed. Walk thru the setup wizard with a wired PC and web browser. Be sure to not enable Access Controls, Armor, Circle or Traffic Meter. Try a speed test with Ooklas installable speed test app with the wired PC.
