ptrike
May 07, 2017Follower
Cant get Orbi ethernet (hardwired) to work
I can not get my computer to find internet through a cat5 hooked directly to one of the ethernet ports on the main router. My new Orbi is up and working wirelesly just fine. Please help...
OrbiMan
May 07, 2017Luminary
More info needed about your computer. But basic steps like making sure the cable is good. Making sure the light on the Orbi and computer are blinking. Making sure you restart the computer. Make sure that your computer is using dhcp instead of static address
