SFPaulyT
Jan 06, 2019Initiate
Can't load large websites or download data despite speed test of 200MPS
I have used the Orbi system for more than a year now without problems. I have gigabit service from Comcast - have speeds of 800M with Ethernet connection, 600M at Orbi router and 125-150M throughout 3...
Jan 06, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Are you seeing problems on both wired and wireless connections with web sites?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
