tuna_ertemalp
Jul 10, 2019Luminary
Can't log in to netgear.com & GS108Tv3 since 7/9/19 ~9pm PST: "Something went wrong. Try again."
This started happening last night, and continuing to happen 12hrs+ later. Searching the COMMUNITY here for "Something went wrong. Try again." only resulted in one slightly useful thread that also was...
- Jul 12, 2019
Here is a copy/paste of progression of relevant parts of the conversation I had with support:
1) "We reported this already to the IT Team since they are the one who handle the accounts. We are confirming as well if it was already fixed."
2) "None so far. I am still waiting from the IT Team feedback about this. Will let you know once I got an update."
3) " I got an update now. The reason for this is because our system before have migrated to new system now. So other accounts was migrated to the new system causing the issue. I do apologize for the inconvenience it brings to you. That was the update I got from them."
Jul 10, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Test the Orbi system with out this switch connected.
Then test Orbi with the switch connected and disable ALL IGMP protocols ON this switch.
If your having problems with this switch, please post about that over one the switch forum.
I see this when trying to access accounts.netgear.com and I'm at work not using any NG products:
403 ERROR The request could not be satisfied.
Bad request.
Generated by cloudfront (CloudFront) Request ID: V3kqV9t2lZrQKpMC2YKjGuhqaWT21d2kxfOH0yB69J5CdlYiCBAdNQ==
Does this work for you?
https://www.netgear.com/mynetgear/registration/login.aspx
is working for me.
tuna_ertemalp
I just did a test and basically proved that it has nothing to do with my router RBR50 in router mode (latest firmware 2.3.1.60 connected to Xfinity modem without any Mfr insignia on it that is in Bridge mode with all its radios and SSIDs turned off, and all IGMP+Green stuff is turned off on the switch as reported above):
I took my iPhone, turned off wifi on it, went out on the street, nothing but AT&T signal, went to netgear.com in iPhone Chrome, clicked on the head icon in upper right of webpage, clicked on Sign In button at the bottom of the resulting popup, entered my username/pwd as it has been for weeks now, spelled all correctly for the umpteenth time since late last night, and got the same issue. In other words, this has nothing to do with my Orbi or managed switch. It is directly on accounts.netgear.com. And, I cannot find a forum for that. And, my email to support is falling on deaf ears.
Thanks for trying, though, my friend. I think your very last observation via cloudfront is the issue here.
Yes, that link works to show me my registered devices, just as SUPPORT and COMMUNITY logins work, by not going through the problematic accounts.netgear.com.
Tuna
