tuna_ertemalp
Jul 10, 2019Luminary
Can't log in to netgear.com & GS108Tv3 since 7/9/19 ~9pm PST: "Something went wrong. Try again."
This started happening last night, and continuing to happen 12hrs+ later. Searching the COMMUNITY here for "Something went wrong. Try again." only resulted in one slightly useful thread that also was...
- Jul 12, 2019
Here is a copy/paste of progression of relevant parts of the conversation I had with support:
1) "We reported this already to the IT Team since they are the one who handle the accounts. We are confirming as well if it was already fixed."
2) "None so far. I am still waiting from the IT Team feedback about this. Will let you know once I got an update."
3) " I got an update now. The reason for this is because our system before have migrated to new system now. So other accounts was migrated to the new system causing the issue. I do apologize for the inconvenience it brings to you. That was the update I got from them."
Jul 10, 2019Guru - Experienced User
Ya seems to be a site issue rather then anything else.
Contact NG support or send a PM to Blanca_O
Good Luck.
tuna_ertemalp
Already had emailed NG support in the middle of the night, still no response, so I sent them an email again with a link to this thread. And also PM'd the moderator you suggested with details, but so far noone contacted me. :smileysad:
This is very disheartening. I am basically just a sitting duck waiting to make someone's priority list.
Tuna
- tuna_ertemalpJul 11, 2019Luminary
And, last night, almost seemingly 24hrs later, the issue went away and I am now able to log in using my Netgear account. Either my emails/PMs helped without having been told anything as to what was wrong, or something happened previous night that put my account into a "24 hour jail," or there was something wrong with the accounts.netgear.com's handling of my netgear account during that time that either cleared up or got fixed. In any case, if someone had a finger in fixing this and is reading this: I am thankful!
Tuna
PS: And, as I was typing this post, I just received a case# from Netgear support for my emails yesterday, about 12hrs after it started working again, so it would seem it wasn't them.
- FURRYe38Jul 11, 2019Guru - Experienced User
Thanks for letting us know. Please mark this as solved so others will know.
Enjoy.
I will as soon as the cases (yes, cases; they opened TWO of them!) opened by Netgear end up in a resolution, possibly with the root cause of what happened and what was done about it, after I post about those findings, if any. That would be a more useful solution. ;)
