starnz
Jan 24, 2021Aspirant
Can't log in to orbi, app shows satellites as not connected
Hello, I have three Orbi products, 1 RBR50 and 2 RBS50s. They all seem to be working although I question if the satellites are from time to time. I tend to check the connected devices on the app but ...
starnz
Thanks for the reply....
I am running FW V2.7.2.102. My ISP device is an Arris BGW210-700 via ATT
Jan 24, 2021Guru - Experienced User
Your ISP Modem already has a build in router and wifi. Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- vajimJan 24, 2021Master
FURRYe38 wrote:Your ISP Modem already has a build in router and wifi. Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopAnother double router scenario......wow?
- starnzJan 24, 2021Aspirant
I configured the Arris to be in bridge mode. I then restarted the Arris and reconnected the Orbi but am still having the same issue. The "Basic" tab just spins while the "Advanced" tab works except for the "Attached Devices" portion.
Thanks for everyone's help thus far. Any other suggestions?
- FURRYe38Jan 24, 2021Guru - Experienced User
What browser are you using? Try Firefox or Opera GX.
I had previously configured the Arris router to work alongside the Orbi by disabling all the Arris radios. It had worked in the current set-up for over two yrs. I did not configure the IP Passthrough however, but I just adjusted it as requested. After logging out of Orbi then back in, I still have the same issue.
I am going to try your othr suggestion and set the Arris as a transparent bridge or in modem only mode. Will report back soon.
starnz wrote:I had previously configured the Arris router to work alongside the Orbi by disabling all the Arris radios. It had worked in the current set-up for over two yrs. I did not configure the IP Passthrough however, but I just adjusted it as requested. After logging out of Orbi then back in, I still have the same issue.
Ok but what value and or advantage does running the Aris router with the Orbi?
The Arris router is from my ISP and doubles as my modem.
