DESIi1
Apr 29, 2017Star
Can't log into either RBS50
I can log into the RBR50, I have left the router with the default login. But I can not log into either satellite. I just updated all three to 1.9.1.12. Should all three have the same logi...
loomis1975
Apr 29, 2017Luminary
Yes, they should all three have the same login and password. Give them a couple hours, and then reboot them all if you still can't access the satellites.
