DESIi1
Apr 29, 2017Star
Can't log into either RBS50
I can log into the RBR50, I have left the router with the default login. But I can not log into either satellite. I just updated all three to 1.9.1.12. Should all three have the same logi...
peteytesting
Apr 29, 2017Hero
for security reasons you should change the login credentials during the initial setup
suggest you factory reset and run the initial setup process again and ensure you change the login details , that should also fix your issue
DESIi1
Apr 30, 2017Star
The backhall signal is dropping to zero, it was as flat as the other signals before I upgraded the firmware to the latest.
Rebooted the router with no change. BTW - I resolved the login problem, it was user error, the password was changed.
