sandman512
Mar 04, 2020Apprentice
Can't log into ORBI via web browser.
So, trying to log into my ORBI system via my web browser(Chrome). i have done this in the past mutliple times with no issues. For some reason today when I go to log int, it brings we to a page skin...
- Mar 04, 2020
So did a reset via the button on back. Logged in via 192.168.1.1 nd was up and running. Thank you. Still, strange what happened, but back to business!
sandman512
It is the latest firmware I believe, 2.5.1.8.(that is what shows up when trying to log in).
Also, I have cleared everything and still no luck. Just triedhttp://192.168.1.1/index.htm on chrome, no luck. Safari isn't working either.
EDIT: Just chrome on another PC, no luck. Just tried FF, no luck.
Mar 04, 2020Guru - Experienced User
Press the reset button in back for 15 seconds then release. The top ring LED should blink WHITE then slowly puslate WHITE. Being the setup process. Use a wired PC connected to the RBR. Clear all browser caches, then use a browser, FF or Safari. The setup wizard should begin at http://192.168.1.1 or orbilogin.com. Walk thru the setup wizard and besure to write down all important information for safe keeping.
Be sure your PCs networking set set up for automatic obtain IP addressing as well.
