sandman512
Mar 04, 2020Apprentice
Can't log into ORBI via web browser.
So, trying to log into my ORBI system via my web browser(Chrome). i have done this in the past mutliple times with no issues. For some reason today when I go to log int, it brings we to a page skin...
- Mar 04, 2020
So did a reset via the button on back. Logged in via 192.168.1.1 nd was up and running. Thank you. Still, strange what happened, but back to business!
CrimpOn
Mar 04, 2020Guru - Experienced User
sandman512 wrote:So, trying to log into my ORBI system via my web browser(Chrome). i have done this in the past mutliple times with no issues. For some reason today when I go to log int, it brings we to a page sking me to enable parent controls and it says I'm looged in even though I am not. The URL I am using is as follows:http://www.orbilogin.com/index.htm
Any advice. Thank you.
Can you take a screen shot and post it?
Is anything else visible on the screen, such as the menu on the left or the "Logout" in the upper right?
When I access my Orbi web interface, the first thing that happens is a login prompt pops up ("admin" plus password). This does not happen to you?
sandman512
- FURRYe38Mar 04, 2020Guru - Experienced User
Be sure to do a backup configuration to file for safe keeping. Saves time if a reset is needed later on.
Please mark your thread and solved so others will know.
Enjoy. :smileywink:
sandman512 wrote:So did a reset via the button on back. Logged in via 192.168.1.1 nd was up and running. Thank you. Still, strange what happened, but back to business!
- AnonymousMar 04, 2020
FURRYe38 wrote:Be sure to do a backup configuration to file for safe keeping. Saves time if a reset is needed later on.
Enjoy. :smileywink:
factory reset is for lost passwords. Enjoy :smileyhappy:
- BoilerPlateMar 04, 2020Apprentice
This and many other factory reset posts proves your incorrect.
Enjoy. :smileylol:
