justmarks
Dec 12, 2021Aspirant
Can't login to Microsoft applications from Android phone when connected to Wifi
This is SUPER weird. Simply put, I can't login to Microsoft products from my Android phone while on Wifi. I've seen this happen with Microsoft Family Safety, Authenticator, and OneNote - they all f...
justmarks
The Model is the RBR50 with the latest firmware - v2.7.3.22
I have replicated the issue on 2 different Google Pixel phones, Pixel 3aXL and Pixel 5a. I have not seen the issue on Fire tablets which are the only other Android device I have.
In OneNote, i'm show as "Working Offline sign in required E0000024 c3zov) and when i try to sign in, it fails and just asks me to sign in again
In Family safety, it says "Sign back in" and when I click it, I get Error An Error occurred. Please try again later. (See photo)
Bitdefender Armor is NOT enabled but parental controls are. This phone is NOT in a profile where there are parental controls.
CrimpOn
Dec 12, 2021Guru - Experienced User
I just love "an error occured. Please try again." SO helpful!
My internet search for "Working Offline sign in required E0000024 c3zov" turned up a bunch of hits, so you are not the first person this has happened to. (not much consolation). I know so little about Microsoft apps (zero counts as 'little'?) Do any of these web results appear to be relevant to your situation?
- justmarksDec 13, 2021Aspirant
Thanks CrimpOn - I've definitely done my due diligence on this and those search results have not helped. The only "workaround" has been changing to a different network hence I believe there is an issue with the router + configuration.
- FURRYe38Dec 13, 2021Guru - Experienced User
I'm attaching an image from the "modem". It's Model FOG421
NOTE, my previous router did NOT have this issue, it's only since the Orbi was introduced.
