Nrk
Jun 24, 2021Aspirant
Cant login to Orbi RBR 40 from desktop
I have an Orbi RBR40 with 1 satellite. I am not able to login to the router via desktop. going to 192.168.1.1/Routerlogin.net/10.0.0.1 just shows timed out . I am connected via Wifi. The default gat...
Jun 24, 2021Guru - Experienced User
- NrkJun 24, 2021AspirantThe cable from the ISP is connected directly to Orbi. There is no router from the service provider.
Firmware V2.6.2.104.
Haven't factory reset the router since the initial config- FURRYe38Jun 24, 2021Guru - Experienced User
Try a reset with the RBR disconnected from the modem.
