catlife's avatar
catlife
Initiate
Jun 24, 2019
Can't login to orbi
I recently moved and my Orbi is not letting my son connect via a wired connection via ethernet cable from the satellite. I need to log in to see if I temporarily blocked him (I used to do that regula...
  • CrimpOn's avatar
    Jun 25, 2019
    A "factory reset" is performed by sticking a paperclip into the tiny "reset" hole on the back of the router for 10-12 seconds until the power LED on the back begins to flash amber.  That puts the Orbi back into "out of the box" condition.  i.e. the web interface has user ID "admin" and password "password".  The WiFi has the SSID and password that is on the label of the router.
    Good Luck
