Mageezer
Nov 20, 2022Aspirant
Can't login to orbilogin or 192.168.1.1
Try to reset with serial...
Stuck in endless loop of security questions I don't know. Younger sisters name? I don't have a younger sister.
1 Reply
The problem with the password recovery option is that if you didn't set it up, there isn't any correct responses.
So if you don't know the login password and didn't setup the password recovery, then you'd need to factory reset to get back in
