scooterman2
Sep 14, 2017Tutor
can't logon to satellites (RBR50)
I can't logon to the satellites to upgrade FW. It is not reconginzing the login credentials (which I assume should be same as router). Now I am stuck - updated router to v2 but satellites stuck with...
- Sep 14, 2017
resetting now. hopefully does the trick.
Dustin278
Sep 14, 2017Apprentice
scooterman2 wrote:I can't logon to the satellites to upgrade FW. It is not reconginzing the login credentials (which I assume should be same as router). Now I am stuck - updated router to v2 but satellites stuck with V1.12.0.4.
Have you tried the default login?
login: admin
password: password
otherwise reset router and the default should work then
- scooterman2Sep 14, 2017Tutor
thank you. Now I just need to figure out how to get the latest FW (img file) for satellites as file from dropbox won't upload.
