scooterman2's avatar
Sep 14, 2017
can't logon to satellites (RBR50)
I can't logon to the satellites to upgrade FW. It is not reconginzing the login credentials (which I assume should be same as router).  Now I am stuck - updated router to v2 but satellites stuck with...
  • scooterman2's avatar
    scooterman2
    Sep 14, 2017
    resetting now.  hopefully does the trick.
