Zathraskin
Mar 11, 2018Aspirant
Can't Manage Router when Connected via Satellite and Can't Manage Satellite when connected to Router
Hi Guys, I just got the RBK50 Kit and everything is setup in AP mode and it all seems to be working correctly. One thing I noticed however, is that when I'm connect to the satellite, either by b...
- Mar 11, 2018So I was able to fix this by a simple reboot of the satellite. Some kind of glitch clearly!
RocketSquirrel
Mar 11, 2018Luminary
This is not expected behavior. I can manage my router & satellites from any location.
Perhaps you should perform a sanity check on your network, e.g., check that your assigned LAN addresses are all unique.
- ZathraskinMar 11, 2018AspirantSo I was able to fix this by a simple reboot of the satellite. Some kind of glitch clearly!
