encrawford
Jul 31, 2019Tutor
Can't move throughout my house without having to reconnect
I have an RBR40 and two satellite RBS20 units. I have great bandwidth throughout my entire three-story house as long as I don't switch locations. However if I walk from the basement to the third floo...
CrimpOn
Jul 31, 2019Guru - Experienced User
Could you please provide more information about the configuration.
How large is each floor?
Where are the router and two satellites located?
Thanks
- CrimpOnJul 31, 2019Guru - Experienced User
Do you have the Orbi "app" on either the iPhone or iPad? When a device is connected, under "Device Management" it will show the "Link Rate". Does it drop to zero as you move (slowly) from one location to another?
- encrawfordAug 01, 2019Tutor
I do have the app and will check this out tonight.
- CrimpOnAug 01, 2019Guru - Experienced User
Thanks for the drawings.
- Are any of the "options" present in the actual build?
- Any idea what material is in the floors?
i.e. are they renforced concrete slab, or wooden joists and flooring?
Is there a specific point or points where the signal seems to "disappear"?
See attached house layout with the location of the Orbi units marked
