SLBB
Jan 02, 2020Follower
Cant open apps on my LG smart tv after new router installed
I can not open any apps on my smart tv after connecting to wifi orbi RBK22. my TV shows connected but no apps will open
Feb 27, 2020Guru - Experienced User
Any progress on this?
SLBB wrote:I can not open any apps on my smart tv after connecting to wifi orbi RBK22. my TV shows connected but no apps will open
- DrfamulacFeb 28, 2020AspirantThis same thing happened to me and It was because the orbi was on router mode, not access point mode. Once I switched to access point mode, all works great. I had my original Verizon router in the basement doing the routing. I did the orbi auto set up and just assumed it would detect and make the orbi an access point. It didn’t, and I ended up with two routers on the network which isn’t good. Switch the orbi to access point (AP) mode and it will fix the issue.
- FURRYe38Feb 28, 2020Guru - Experienced User
For future reference.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
